Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › How to define a rigid surface for a solid › Reply To: How to define a rigid surface for a solid
1617836513
Hi, I know how to set the part as a rigid body. But after I set the drive part as rigid body, I have the following problem:
   The drive part is not fully meshed, why is that?
   I want to add a distal displacement to the surface of the drive part that rotates around the Z axis, which will conflict with the constraints of the rigid body.
I want to achieve something like figure 3 and 4.
