Ansys Learning Forum Forums Discuss Simulation Fluids Lee model with k-e pressure drop and temperature change incorrect. Reply To: Lee model with k-e pressure drop and temperature change incorrect.
hurch346
I have tuned the condensation coefficients in the Lee model to match my experimental results for condensation rate, and i have also ensured that the results are converged via report definitions and running the model until all residuals sufficiently low, which still gives the same results. Â
