Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Lee model with k-e pressure drop and temperature change incorrect. › Reply To: Lee model with k-e pressure drop and temperature change incorrect.
You've not set the inlet pressure as zero, read the panel carefully. So that's behaving as expected.
Try just modelling the moist side and set a convection boundary for the cold side. It's fewer cells and probably easier to troubleshoot. Domains with separate fluid zones tend to be more difficult to work with.
Latent heat is accounted for, but as I don't know what you've set relative to what you think you've set and whether the results are anywhere near converged it's somewhat difficult to comment. Condensation models are not simple, so chances are you've missed something or haven't correctly adjusted the model parameters.
