Ansys Learning Forum Forums Discuss Simulation Electronics Why are the S-parameters so different? Reply To: Why are the S-parameters so different?
Praneeth
Thank you for reaching out to the Ansys learning forum. Your patience is much appreciated.
Please check if you are using the correct impedance values. If possible, please share a comparison of the s-parameters of the circuit element before and after connecting it with the Ansys HFSS software model.
Best regards,
Praneeth.
