Ansys Learning Forum Forums Discuss Simulation Fluids Sector Mesh generator Reply To: Sector Mesh generator
Usman
Following is the MONITER file after using CR Utility:
FORTE Runtime Environment is 2023 R2 (15-May-2023 01:45:54 AM)
LICENSE INFORMATION:
LicNum: 373361.  License for SCEDWLW1123985_AD_HUD_AC_UK-u2061120-31576-001264 is obtained from the ANSYS license service running on SCEDWLW1123985.AD.HUD.AC.UK.
Process #8 (rank 7) on host SCEDWLW1123985 will be used as the dedicated communication server.
Setting server memory parameter to 1000
     *                      ANSYS Forte 2023 R2                      *
     *                    Build Date: May 15 2023                    *
     *                   Forte Simulation Package                    *
     *                Copyright (c) 2023 Ansys, Inc.                 *
     * Unauthorized use, distribution or duplication is prohibited.  *
     *   This product is subject to U.S. laws governing export and   *
     *     re-export.  For full Legal Notice, see documentation.     *
The following arguments were passed:
 -i CR_A.ftsim
 -l FORTE.log
 -rn Nominal_
 -o Nominal.ftres
Using MPI Version: Intel(R) MPI Library for Windows* OS, Version 2021.8 Build 20221129
This run is using 8 MPI processes.
1 MPI process(es) will be used as the dedicated communication server(s).
On process #1 (rank 0) on host SCEDWLW1123985 there are 3 core(s) available and 1 thread(s) will be used.
On process #7 (rank 6) on host SCEDWLW1123985 there are 3 core(s) available and 1 thread(s) will be used.
On process #5 (rank 4) on host SCEDWLW1123985 there are 3 core(s) available and 1 thread(s) will be used.
On process #3 (rank 2) on host SCEDWLW1123985 there are 3 core(s) available and 1 thread(s) will be used.
On process #2 (rank 1) on host SCEDWLW1123985 there are 3 core(s) available and 1 thread(s) will be used.
On process #4 (rank 3) on host SCEDWLW1123985 there are 3 core(s) available and 1 thread(s) will be used.
On process #6 (rank 5) on host SCEDWLW1123985 there are 3 core(s) available and 1 thread(s) will be used.
 Error reading variable: project_version
 Error reading variable: is_crank_based
MPI Finalized
Error: FORTE simulation failed to complete
Licenses Released
