Ansys Learning Forum Forums Installation and Licensing Ansys Products Learning Hub Additive Courses Issue Reply To: Learning Hub Additive Courses Issue
Jack Devine
Thanks for the update, I see that the Ansys Sound course was moved out of the Additive building. However, it seems that the Introduction to Additive Print course is still missing from the new Learning Hub. I attached two screenshots below of the old Learning Hub with the Additive Print course, which I found to be the most important of all courses included. Thank you for the help
