Ansys Learning Forum Forums Discuss Simulation Photonics scattering calculation with gaussian beam in FDTD Reply To: scattering calculation with gaussian beam in FDTD
yuqizhu
re high NA gaussian beams, the side normal profile looks ok now after I moved the PML farther out like you suggested. However, the z- noraml cross sections still don't look as gaussian as i'd expect. Here is a screenshot (NA=0.9) in my google drive; I can't upload images today for some reason.
For low NA beams, I have a different problem, (NA=0.11). Both z- and y-normal profiles look wavey. The lower PML in z is ~2.5 lambda way from the injection plane, and simulation span is X/Y is ~15 um. Is this also from some numerical artifacts?Â
