Ansys Learning Forum › Forums › Discuss Simulation › Fluids › ansys aqwa : hinge connector › Reply To: ansys aqwa : hinge connector
August 5, 2024 at 12:55 pm
The stiffness about a hinge joint local x axis can be defined, as shown in Figure 2.
Please check if there is any rotation response about the global Y and/or global Z axis. If yes, the joint force about global x axis (in Figure 3) could be non-zero, as the hinge joint local x axis does no longer parallel to the global X axis.
Ashish Khemka
