Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Some questions about the heat transfer coefficient › Reply To: Some questions about the heat transfer coefficient
Yifan Chen
Thank you very much for your reply. Are you referring to whether the axis of a cooling channel is aligned with the y-axis? If so, it seems that my axis is aligned with the x-axis.
