Ansys Learning Forum Forums Discuss Simulation General Mechanical Consultation about Exporting Data Reply To: Consultation about Exporting Data
zzhang868
Hi Aniket, thanks for your feedback.
2. Regarding the material assignment object, I want to ensure I understand it correctly. The difference between "Titanium Alloy" and "Titanium Alloy Assignment" is that "Titanium Alloy" cannot be edited under "Mechanical" (it can only be edited under "Engineering Data" in the workbench), whereas "Titanium Alloy Assignment" can be edited directly under "Mechanical."
Additionally, I am wondering if it's possible to change its property following a distribution. For instance, can I set its value to be 10, 10.1, 10.2, etc., and run the simulation? This would generate results for different material properties at once. Could you please share any tutorials about it?
5. I do not import data from somewhere but just export data from transient thermal anslysis and export "Total Deformation" as txt file, for example, from the above figure and find that the node number starts from non-zero number. I am wondering whether there is anything wrong with my simulation. If so, do you have any suggestions about troubeshooting?
Many thanks!
