Ansys Learning Forum Forums Discuss Simulation Electronics determining turn directions in cylindirical coil:clkwise-counterclkwise Reply To: determining turn directions in cylindirical coil:clkwise-counterclkwise
HDLI
Hello Serdar,
       I think the red coils and blue coils have entered current, and then the green coils will generate induced voltage, is it correct? Could you show the blue coils and green coils?
       When you define coil terminal, the coil terminal's direction is voltage or current reference positve direction. You can use current of 0 or big resistance in external circuit to present open circuit.
       When the coils are symmetry, the sum of the green coils may have 0 voltage as what you did. However, it seems that the blue coils are not symmetry.
       To get what you expect, you have to design perfect turns for each coil after comparing induced volatge for each green coil.
HDLI
