Ansys Learning Forum Forums Discuss Simulation General Mechanical Defining custom material based on ASME BPVC Div. 2 Reply To: Defining custom material based on ASME BPVC Div. 2
Armin
Hi Sigurd, You should use plastic strain versus true stress to define the hardening (stress-strain) curve of your metal. Initial yield stress (0.2% rule) and ultimate tensile strength are commonly defined based on engineering stress.
