Ansys Learning Forum Forums Discuss Simulation General Mechanical how to set up to find the pretention force of the bolted joint Reply To: how to set up to find the pretention force of the bolted joint
Kaushal Vadnere
Hi Ji Shiyu!
You can calculate the pretension force of the bolt using this formula:
T = K*F*d
Where,
T = Torque in Nm
K = Constant which is usually taken as 0.2 for normal dry conditions,
F = Axial bolt force or pretension force in N
d = Nominal diameter of the bolt in m.
To apply bolt pretension in Ansys Mechanical, you can use bolt pretension object.
Refer to this free Ansys Innovation Course to learn how to setup bolt pretension: Modeling the Bolt and Preload | Ansys Innovation Courses
