Ansys Learning Forum Forums Discuss Simulation Fluids Volume Fraction too Low. How to Improve? Reply To: Volume Fraction too Low. How to Improve?
You're setting the HTC on the "outside" of the model to avoid having to model another fluid zone. If you also have tubeside condensation then it's not a simple boundary and you need to do some more thinking.
The +/- is flow/flux in/out of the cells to "outside" with outside being where there's no mesh. So on an inlet a +ve flux is fluid entering the flow domain, a -ve value is flow leaving the modelled domain.
