Ansys Learning Forum › Forums › Discuss Simulation › Fluids › TUI command for adding Data File Quantities › Reply To: TUI command for adding Data File Quantities
SRP
You need to change cff -files to No using TUI: /file> cff-files>no  then you can see the option of data file options under 'files'.
Thank you.
