Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › User Defined Result › Reply To: User Defined Result
Dustin Lochmüller
Hello!
I greatly appreciate your help! Thank you, this has helped me a lot. I'm doing it now, similar but a bit different. I just create a user-defined result for each time step and add the maximum value to the parameter set.
Thank you, it really helped me a lot.
Dustin
