Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Convergence Issue – Thermal Electric Conduction Simulation › Reply To: Convergence Issue – Thermal Electric Conduction Simulation
dlooman
That's probably why it didn't converge.  There was no load.  You have to apply a current to produce joule heat.  Line Search can be turned on with the command lnsrch,on if you're not in the Mechanical gui.
