Ansys Learning Forum Forums Discuss Simulation General Mechanical User Defined Result Reply To: User Defined Result
Dustin Lochmüller
Thank you, Erik! It is working now. My mistake was that I always did it the other way around (first defined the path and then the geometry) and that didn’t work.
Do you also have some advice on how to export the result as a table? The script recording is not showing any output when I run it by hand.
If I use "res.ExportToTextFile("PATH_TO_FILE")" it exports the data from the path over distance. I want to change the X-Axis to Time and export those Min, Max, and Average values, but that seems not to work. I did the following but still got the values over distance:
res.GraphControlsXAxis = GraphControlsXAxis.Time
and then I got this:
but I want to export this:
