Ansys Learning Forum Forums Discuss Simulation LS Dyna No wear analysis results Reply To: No wear analysis results
igandiko
I suggest you run the example shown here (https://ftp.lstc.com/anonymous/outgoing/support/EXAMPLES/wear_for_distribution_with_pdf.tar.gz) and follow the steps for wear calculations. You can then repeat the procedure with your model. If you still have issues, then we cannot resolve it on the forum. We may need your files. Please create a support case if you have access to support.Â
