Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Convergence Issue – Thermal Electric Conduction Simulation › Reply To: Convergence Issue – Thermal Electric Conduction Simulation
August 1, 2024 at 4:32 pm
Did you apply a current to the other end of the wire? Is the electrical conductivity temperature-dependent? If you ramp the current on slowly the solution should converge, but it's helpful to turn on Line Search. Sometimes the default converge criteria are way too small, preventing convergence.
