Ansys Learning Forum Forums Installation and Licensing Ansys Products How to use ESCHECK command in Ansys Mechanical ? Reply To: How to use ESCHECK command in Ansys Mechanical ?
Asitang
If you are having trouble with convergence, perhaps due to excessive mesh distortion, you might consider applying load more gradually i.e. by increasing the substeps. If that doesn't work, you should try improving the mesh and checking the stability of the material. Additionally, you may consider using the Nonlinear Mesh Adaptivity (NLAD) approach if the problem persists.
Hope this helps!
Asitang
