Ansys Learning Forum Forums Discuss Simulation Fluids FSI Simulation of a Wing with a Flap: Guidance Needed on Setup and Coupling Meth Reply To: FSI Simulation of a Wing with a Flap: Guidance Needed on Setup and Coupling Meth
idenyu8701
Thank you very much for your help in successfully setting up the one-way fluid-structure interaction!
Now, I need to move towards the goal of two-way fluid-structure interaction, but I am currently encountering three issues:
  1. Is it true that one-way FSI cannot integrate the changes in the fluid and solid into a complete animation, and only two-way FSI can create a complete animation of fluid-structure interaction?
  2. I have tried adding the System Coupling module, but I do not quite understand the settings for the Data Transfer part. Could you provide me with some suggestions?
  3. Regarding Fluent, Transient Structural, and System Coupling, all three modules have their own Step Control settings. My question is, do the Step Control settings of these three modules need to be identical?
    I look forward to your reply. Thank you very much.
