Ansys Learning Forum Forums Discuss Simulation General Mechanical Additive Print: Minimum Support Height Reply To: Additive Print: Minimum Support Height
Akshay Maniyar
Hi Glenn,
Did you uncheck the check mark ‘Simulate with support’? You can also check the below Ansys help like for more details.
2.3.5. Simulating Without Supports (ansys.com)
Thanks,
Akshay Maniyar
