Ansys Learning Forum Forums Discuss Simulation General Mechanical User Defined Result Reply To: User Defined Result
Dustin Lochmüller
Thanks for the prompt answer, I have already tried that. I already set the location parameter with the path (see code excerpt above). If I set the location parameter again with a body, then the scoping method changes to “Named Selection” and the path is no longer used.
