Ansys Learning Forum Forums Discuss Simulation General Mechanical Consultation about Exporting Data Reply To: Consultation about Exporting Data
zzhang868
Many thanks for your kind help! Yes, I am using ANSYS Mechanical.
1. “add a result scoped to a single body instead of "all bodies" that is default” -- Could you please share how to add a result towards a single body? Currently, if I add any solution, it is automatically attached to all bodies.
2. For the simulation, I only want to change the value of a material property and rerun all simulations, I am wondering whether I can do it more effectively instead of clicking buttons via the interface.
3. Thanks, I will check it.
4. Thanks, could you please share any links/resources about how to export it using APDL instead of using the interface?
5. Got it. Is it normal to have node number starting from non-zero value? I have thought that node number should start from 1.
