Ansys Learning Forum Forums Discuss Simulation Fluids Balance de masa Reply To: Balance de masa
manuel.pacherres
Hi Nick FL,
Thanks a lot for the reply.
When I simulated only water, in the output condition I activated the "Prevent reverse flow" option, for some reflux cases, that way my mass balance gives good results. However, when I use the multiphase model to deal with nanofluids I am not presented with that option.
So if I extend the tube at the outlet, would that improve my temperature gradient and my mass balance? I will try it!
I will also check the velocity vectors at the outlet to see if they are consistent.
Thanks again.
