Ansys Learning Forum Forums Discuss Simulation Fluids Balance de masa Reply To: Balance de masa
manuel.pacherres
Hi Federico, the residuals for all cases are below 10e-07 more or less, only for continuity it is around 10e-04. However, I tried to reduce the convergence criteria to get lower residuals (and thus perform more iterations) and the result is the same.
Regarding the mass imbalance, if my mass flow at the inlet is 0.5 kg/s and the mass balance given by ansys is 0.01395431 kg/s, my mass imbalance in percentage would be 2.79% right? Would that be correct?
