Ansys Learning Forum Forums Discuss Simulation General Mechanical Double pin connection – Internal solution magnitude limit was exceeded Reply To: Double pin connection – Internal solution magnitude limit was exceeded
Akshay Maniyar
Hi Karel,
As per the error message, it looks like your model is undergoing rigid body motion. Can you recheck the pin contacts? I guess, you have not selected all the surfaces. Also, you can check the initial contact information to see if any contact is in far open status.
Thanks,
Akshay Maniyar
