Ansys Learning Forum Forums Discuss Simulation Fluids Pressure wave through deformable tube Reply To: Pressure wave through deformable tube
Swapnil
I tried with wide range of Youngs modulus and Poisson ratios (0.3 to 0.48). But could not get the desirable effect. What do you mean by "add a thread with the Mechanical settings into the Structures channel"?
AND
For fluid zone what could be the boundary condition at inlet/outlet, if not constant dp?
