Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Not able to create Force Monitor in Discovery 2024 R2 › Reply To: Not able to create Force Monitor in Discovery 2024 R2
Devendra Badgujar
Selections with facteded body can sometimes be difficult as there are multiple facets. Select all does not give option to add as a facet region currently so only option is to box select and add the region to define simulation conditions.
I would recommend please use the Solid 3D CAD instead of facted body for simulations as its easy to setup and you cna make quick design changes to it. The geometry is avilable to download from the course.
Similarly for the rear wing, you are not able to define force because the facets on which the conditions needs to be defined has not been added as facet region.
Thank you for your understanding!
Devendra
