Ansys Learning Forum Forums Installation and Licensing Ansys Products Unusual Bug for .deb File Conversion Reply To: Unusual Bug for .deb File Conversion
scorsett
Thank you! That solved the file-conversion problem we were having.
Now, we're running into a new challenge on the cluster. When we attempt to run fdtd simulations using our standard batch files (now running v242 instead of v231), we are getting the error:
"Messages file /ansys_inc/shared_files/licensing/language/en-us/ansysli_msgs.xml does not exist."
Based on a forum post for a similar problem, it sounds like this may be due to a licensing issue. Is it possible that existing licenses may not support running v242 in an HPC environment? We should have access to 60 lum_fdtd_solve licenses, but I'm not certain how to check version compatibility.
