Ansys Learning Forum Forums Discuss Simulation LS Dyna How to secure analysis stability when using AutoDyn solver Reply To: How to secure analysis stability when using AutoDyn solver
Chris Quan
Can you check Energy Summary to see if hourglass energy is high, comparing with Internal Energy?
What meshing method you used to generate the mesh?
What is the material of these two balls: ductile, brittle, hyperelastic, or porous?
What is the impact velocity?
