Ansys Learning Forum Forums Discuss Simulation LS Dyna I have this kind of error. Is the student license most likely the cause? Reply To: I have this kind of error. Is the student license most likely the cause?
George Karnos
What is your Workflow?
How are you starting the job?
It will not run from inside Workbench. LS-DYNA must be run directly from the LS-DYNA Start Menu.
