Ansys Learning Forum Forums Discuss Simulation Electronics Issue with “Find Conduction Path: Coil Terminal not on any conduction path” Reply To: Issue with “Find Conduction Path: Coil Terminal not on any conduction path”
Reshmi Raghavan
Hello Junaed,
The solution for the same is to check the placement of the sheets where the excitation is defined. The sheets has to be the cross section of hte coils.
