Ansys Learning Forum Forums Discuss Simulation Fluids Volume Fraction too Low. How to Improve? Reply To: Volume Fraction too Low. How to Improve?
abdullahhassan
"how many steps do you need to get flow from the inlet to the outlet?"
actually, I never considered this before. i just calculated these and with velocity 0.0083m/s and domain length (in to out) is 200mm so
1- 24.1s required to travel from inlet to outlet.
2- step size should be = 24.1s  / 1e-5 * 20(iteration/timestep) = 120500 steps.
does this mean, a flow should move from inlet to outlet in 120,000*20 = 2410000 iterations?
