Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Modelling low viscous liquid (water) flow on a viscoelastic porous material › Reply To: Modelling low viscous liquid (water) flow on a viscoelastic porous material
Saptaswa Biswas
I need to see how much water flows through the viscelastic material (amount and velocity), how much flows on the surface (amount and velocity), which paths the flow takes based on the surface topography, and how the gravitational fluid flow exerts shear stress (surface flow) and normal stress (flow through material) on the material and deforms it with time. I already have the rheological data of the material (G', G").
