Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Fluent multiphase modeling using the NIST REFPROP database › Reply To: Fluent multiphase modeling using the NIST REFPROP database
iason.basiakos
Thank you very much for the prompt reply.
So if I get it correctly, I can use the database, but I still need to define two materials, one for the liquid and one for the vapour phase?
If so, as soon as I set a liquid state in the material from the NIST database using the console command: /define/user-defined/real-gas-models> set-state, the vapour state ceases to exist. Could you please elaborate on the procedure?
Thank you very much again
