Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Not able to create Force Monitor in Discovery 2024 R2 › Reply To: Not able to create Force Monitor in Discovery 2024 R2
July 31, 2024 at 9:55 am
Hello Shivaansh,
Can you please share an image of your full Discovery screen inclduing the Design and Physics tree. I want to see how the model is setup.
There are two ways:
- You can use Enclosure where the geometry will get automatically substracted from the domain.
- You can use Cutter bodies to automatically block the fluid flow without having to extract the overlapping bodies from the fluid.
Both options are fine, but the object selection would differ when defining monitors. If velocity monitor is not showing any warning, that means it is correct.
Devendra
