Ansys Learning Forum Forums Discuss Simulation Fluids Difference between Section Tension and Whole cable force-Tension in Aqwa workben Reply To: Difference between Section Tension and Whole cable force-Tension in Aqwa workben
xinyuan.shao
Thank you.
What is the output of the whole cable force then? Is it the tension of the start position of each cable?
