Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Difference between Section Tension and Whole cable force-Tension in Aqwa workben › Reply To: Difference between Section Tension and Whole cable force-Tension in Aqwa workben
Shuangxing Du
I am sorry I made a mistake. The tension at the STARTING end of each section along a dynamic cable could be output as the section tension. For example, the tension at Section#1 is the tension at the anchor.
