Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Problem with using multiple Moving Heat Flux ACT in a given simulation › Reply To: Problem with using multiple Moving Heat Flux ACT in a given simulation
July 31, 2024 at 6:16 am
I have not used this ACT but can you check the solver filer files directory (right click on solution information) and check the input file (ds.dat file) and solver output to see what is going around at this time?
Ashish Khemka
