Ansys Learning Forum Forums Discuss Simulation Fluids FSI Simulation of a Wing with a Flap: Guidance Needed on Setup and Coupling Meth Reply To: FSI Simulation of a Wing with a Flap: Guidance Needed on Setup and Coupling Meth
idenyu8701
Sorry I'm not sure about what you mean.
but I use WB to do my work, and I have a little question because I'm not really sure.
I currently have a question: if I don't use the system coupling, it is a one-way coupling.
If I use the system coupling to set up the subsequent solution, will it be considered a two-way coupling?
Thank you very much!
