Ansys Learning Forum Forums Discuss Simulation Fluids Difference between Section Tension and Whole cable force-Tension in Aqwa workben Reply To: Difference between Section Tension and Whole cable force-Tension in Aqwa workben
xinyuan.shao
Hi!
Thank you for your answer!
I still have one question. In the following figure, the whole cable forces-Tension and section tension have different values for the same mooring section. Why? What is the definition of whole cable forces -tension?
Xinyuan
