Ansys Learning Forum Forums Installation and Licensing Ansys Products Inserting a load at zero deformation Reply To: Inserting a load at zero deformation
mrife
Hi
You can change the 'Longitudinal Stiffness' of a Spring to 'Tabular Data' then enter the force-deflection data points in the table that appears.  After inserting a Spring in WB Mechanical.
Mike
