Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › why calculations are the same for different load sizes or types › Reply To: why calculations are the same for different load sizes or types
armin.abedini
No worries, I just responded to your other post about plastic deformation.
Stress is calculated at the integration points and then extrapolated to the nodes. What you see reported in Mechanical is the averaged values of stress at each node. For a detailed discussion on this topic, please see the (long) thread below: https://innovationspace.ansys.com/forum/forums/topic/integration-point-results-option-in-equivalent-stress/
