Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Not able to create Force Monitor in Discovery 2024 R2 › Reply To: Not able to create Force Monitor in Discovery 2024 R2
July 30, 2024 at 3:17 pm
Hello Shivaansh,Â
Make sure you select the faces from the enclosure. First go to Monitors>>Select the Force as result variable to monitor and then box select your geometry it will automatically select the car faces which were substacted from the enclosure during geometry preperation level.
Note: Hide your orginal car body.Â
Thanks,Â
Devendra
