Ansys Learning Forum Forums Discuss Simulation Fluids Pressure Drop analysis in Packed bed Reply To: Pressure Drop analysis in Packed bed
Jackson Gomes
Hi Obed,
Unfortunately, it is not possible to visualize particles directly in Fluent. You can try post-processing using Ensight.
The error you are encountering is associated with the imported .cas file from Fluent. Verify the fluent setup and try importing it again.
Please access the manual, go to the top menu in Rocky: HELP > manuals > CFD coupling technical manual. For tutorials, go to HELP > tutorial Workshops and check Tutorial 14: Fluidized Bed.
Hope this helps!
Best regards,
