Ansys Learning Forum Forums Discuss Simulation General Mechanical Problem with Transient Structural simulation after Transient Thermal analysis Reply To: Problem with Transient Structural simulation after Transient Thermal analysis
Deepak
Can you try solving the non-distributed mode?
If the above solution doesn’t work then reduce the model size ( by using coarse mesh). Check for running the simulation to confirm the issue was either solver or memory.
Thanks,
Deepak
