Ansys Learning Forum › Forums › Discuss Simulation › Fluids › How to get the applied surface tension with the CSF model ? › Reply To: How to get the applied surface tension with the CSF model ?
July 30, 2024 at 10:33 am
As surface tension is attached to the free surface maths which isn't technically available in all cells it may not be held in a documented storage macro. As such I can't comment further as I'm limited to documented functions. However... the fact that the definitions are held in the various header files is in the manual, and these are in the Ansys Fluent install under .../src means you may find something reading through those.
