Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › STL Convertion › Reply To: STL Convertion
July 30, 2024 at 6:36 am
Keyur Kanade
I assume you have a STL file which you want to use for fluid analysis in Fluent.Â
STL contanins all faceted data. For such files there are 2 approaches.Â
- Use fault tolerant workflow in Fluent Meshing to generate mesh. Please check ANSYS Fluent: Fault Tolerant Meshing Workflow - YouTube
- Use reverse engineering in SpaceClaim to generate geometry from STL and then proceed to mesh that geometry. Please check Reverse Engineering with ANSYS SpaceClaim - YouTube
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
